About 2008 E61 Help
e61white
Peamine sõiduk: 530d
About 2008 E61 Help
Postitus Postitas e61white »
Hello everyone,
First of all, I apologize for writing in English. I'm new to Estonia and I own a 2008 model e61. I want to get information on some subjects that I do not know and I think I can find the most accurate information here.
What happens if the vehicle does not have a spare tire during the technical inspection?
Is it okay if the tire dimensions differ from the factory data during the technical inspection? Also, the car has flanges and the wheels are offset.
Where can I find a spare wheel set for my car?
Where should I buy the first aid kit and fire extinguisher?
Raghza
Peamine sõiduk: M340i xDrive
Re: About 2008 E61 Help
Postitus Postitas Raghza »
They don't usually check if you have a spare tire or not, but you need to have two wheel chocks.
As long as the wheels don't poke out too much and you have all the wheel bolts, you don't have to worry about the spacers.
If your tires are fine and not ridiculously oversized, nobody usually checks if they're within factory specified dimensions or not.
You can get the first aid kit and a fire extinguisher from every supermarket or a parts shop.
RazzKalbass
Peamine sõiduk: E39 525TDS
No, you cant passs MOT with spacers if they see it..UNLESS you have certs.
e61white
Thank you so much for answering
Kert11
Peamine sõiduk: X5 3.0d 135kw
Postitus Postitas Kert11 »
First aid kit is not mandatory if private car. It is mandatory only companie owned cars
e61white
Kert11 kirjutas: 28.11.2022 22:40 14 First aid kit is not mandatory if private car. It is mandatory only companie owned cars
My car does not belong to the company. Just on me. So, if I don't have a fire extinguisher and a first aid kit, will the car pass technical inspection?
Kert11
if private car:
fire extinguisher - mandatory, also that needs to be not older than 10 years, also needs to have yearly verification (valid date on it)
first aid kit - optional, not needed inspection perspective
MairoG
Postitus Postitas MairoG »
e61white kirjutas: 29.11.2022 13:25 50
Yeah, you will pass MOT without them. So dont worry about those. But it`s good to have them both, whenever you need them.
Herts
Postitus Postitas Herts »
G30
e61white
Thank you so much everyone for the replies, I also want to ask a question. What are safety shoes? Can you give an example of a picture please?
MairoG
RazzKalbass
e61white kirjutas: 25.12.2022 18:24 57 Thank you so much everyone for the replies, I also want to ask a question. What are safety shoes? Can you give an example of a picture please?
Postitus Postitas LEDBeam »
e61white
MairoG kirjutas: 25.12.2022 19:05 07 Click on the link https://www.google.com/search?q=t%C3%B5 ... 3&dpr=2.63
yes I guess this. thank you for your help
[/quote]
"ohukolmnurk ja rehvivahetuseks teel ettenähtud tõkiskingad"
I'm not so sure that's what's written here. I think I asked wrong :)
Jaanus_V
Postitus Postitas Jaanus_V »
It says "warning triangle and chochs for changing tires on the road"
Safety shoes for people are like the ones above. Safety shoes for cars are like Ledbeam posted but they are more known as chocks, not safety shoes. Could have asked better. If you take one sentance out of the content and translate it, then these things will happen.
https://www.google.com/search?q=t%C3%B5 ... dsTf67l_HM
e61white
Hello again
I took my car for technical inspection and I couldn't get approval because of the problem in the photo I attached. Where can I find this part and where can I get it done? Thanks in advance for your help.
SHARNIIR;
OV 5.1.2. Kaändmik.: 5. 1.2.2. Kaändteljepolt või kuulligend või puksid on Ulemäära kulunud. Lisainfo: ESISILLA PAREM TAGUMINE
toivoku
Peamine sõiduk: 524td
Postitus Postitas toivoku »
one of the wishbones is worn out, i can help you with parts and replacement
