BMW Road Map East 2018 CIC koos FSW-gen
Silver88
Peamine sõiduk: X5 3.0sd 08’ /X3 F25 2.0iX 13’
Telefon: 56642342
Postitus Postitas Silver88 »
Tere,
Jagan foorumi rahvaga 2018 Ida-Euroopa kaarti CIC unitite jaoks.
E60, E61 ab 11/2008 – 05/2010
E63, E64 ab 11/2008 – 07/2010
E70 ab 10/2009 – 06/2013
E71 ab 05/2008 – 07/2014
E81, E82, E87, E88 ab 09/2008 – 03/2014
E84 ab 10/2009
E89 ab 04/2009
E90, E91, E92, E93 ab 09/2008 – 10/2013
F04 ab 11/2008 – 06/2012
F06 ab 03/2012 – 03/2013
F07 ab 10/2009 – 07/2012
F01, F02, F03 ab 11/2008 – 07/2012
F10, F11 ab 03/2010 – 09/2012
F12, F13 ab 12/2010 – 03/2013
F20, F21 ab 09/2011 – 03/2013
F25 ab 11/2010 – 04/2013
F30 ab 02/2012 – 11/2012
Punkt 1. tõmba kaardid alla. 16.4gb on ligikaudne maht.
Punkt2. Et kaarte installida, siis on vaja FSW koodi. Alljärgnevalt on kirjas info, kuidas oma CIC unitist antud kood ainult USB pulgaga kätte saada.
1. Download and unpack the attached file. (1b and BMW-FSC Generator)
2. Get a USB stick, needs to be a small size, I tried several sticks, 4gb, 8gb and 32gb, but the only one I found that worked in the car was a old 1gb formatted to FAT.
3. Put the files in the 1b folder in the root dir of the formatted usb stick. (You only actually need the copie_scr.sh and fsc.bat files)
4. Go to car and turn ignition on, then sat nav, wait until CIC is booted up.
5. Insert USB stick into port in glove box, wait about 30secs.
6. Put USB stick back into computer and you should now have a 1b.hex file on the stick.
7. Open the BMW-FSC Generator program, open the 1b.hex file, select map you've downloaded and generate the FSC.
Jagan antud lingil torrent faili ja muid vajalikke pluginaid kaartide lisamiseks.
Allalaadimislink on SIIN
Kui on küsimusi, vastame need siin teemas.
bmwster
Re: BMW Road Map East 2018 CIC koos FSW-gen
Postitus Postitas bmwster »
Samuti ei leidu fsc.bat faili teie jagatud rar-ides
I would like to inform other members that I could succeed in getting 1b.hex file only by putting on 2GB Fat formatted usb stick only the file copie_scr.sh and nothing else.
Then I could remove from glove box the stick and found on it the following files : 1b.hex, fsc.bat and of course copie_scr.sh.
SEE TOIMIS!
AivoKommer
Peamine sõiduk: 530D
Postitus Postitas AivoKommer »
Tere, kas keegi reaalselt ka proovinud auto peal, et asi töötab?
Ja kas juba on (BMW ROAD MAP EUROPE PREMIUM 2018-1) väljas?
majuv2ikevend
Postitus Postitas majuv2ikevend »
Mul töötab. f10 ja f11 Neil sai failist koodi genereerida. Aga E60 cic failiga tuleb error.
Pulk peab olema kindlasti FAT ja mitte 32 bitti (ehk siis standard valida formatides kui 16 biti pole valikus) muidu auto faile pulgale ei pane. Kui pulgal oli rohkem faile, siis töötas ka.
2018-1 tuli detsembris välja jah.
AivoKommer kirjutas:Tere, kas keegi reaalselt ka proovinud auto peal, et asi töötab?
bmwster
Ma sain koodi kätte ja sain ka installima aga kui küsis teist usb-d ehk teist faili siis paigutasin pulgale teise faili kuid edasi ei installinud.
maxs30
Postitus Postitas maxs30 »
AAaa
Viimati muutis maxs30, 15.04.2019 21:06 04, muudetud 1 kord kokku.
Jan_Ar
Peamine sõiduk: BMW F48 X1 170kW
Postitus Postitas Jan_Ar »
Kas kellelgi on Road Map Europe East MOTION 2018-1 linki/torrentit ka jagada?
BMW e36 318i ´92 | BMW e46 330xi ´01 | BMW e53 X5 ´04 Sports Package | BMW e91 LCI 325d ´09 | BMW F31 320d ´14 Modern Line | BMW F48 X1 170kW´16
laving
Peamine sõiduk: bmw 525
Postitus Postitas laving »
Miks ei saa postitusi kustutada, kui muuta saab?
Palun see postitus kustutada. Ennist oli siin küsimus, millele juba ise vastuse leidsin.
Viimati muutis laving, 01.12.2018 11:06 53, muudetud 1 kord kokku.
Raido551
Postitus Postitas Raido551 »
tõmbad arvutisse, pakid lahti ja kopeerid mälupulgale.
AllarH
Postitus Postitas AllarH »
Enda autos millegipärast ei hakka uuendama kaarti. Proovisin alguses genereerida FSC koodi õpetuse järgi, aga ei saanudki tehtud ja lõpuks ostsin koodi. Aga nüüd mure sellega, et ei hakka uuendama kaarte ja ei küsi koodi samuti. Tegin prooviks restardi süsteemile aga ikka ei midagi.
Proovisin nii 1 usb varianti kui 3 usb'ga. Tegin täpselt kõik nagu õpetustes, proovisin nii 16gb kui 32gb mälupulkadega aga ei toimi. Ideid, milles asi võib olla?
E91 330D LCI
F31 320D LCI
Volum
Postitus Postitas Volum »
Failide / kaustade asetused usb pulgal valed.
Buumer Auto / 56826000
AllarH
3 USB variandil ei tohiks seal küll midagi valesti minna asetusega, kuna pulgale läheb ainult 1 kaust ja 1 fail eraldi.
Õpetustes kohe peale pulga ühendamist autoga tekib aken kus pakub uuenduse alustust. Mul seda ei teki, nagu ei tunneks pulka ära. Kuigi sama pesa kaudu samalt pulgalt laseb muusikat importida/exportida. Seega see usb pesa iseenesest toimib.
E91 330D LCI
F31 320D LCI
marek555
Postitus Postitas marek555 »
USB pulga lükkad ikka ilusti lõpuni pessa? Endal oli just selles probleem, et ei lükanud täitsa lõpuni pulka :)
marek555
Kui kedagi huvitab, siis on saadaval nüüd juba East PREMIUM USB 2019-2 versioon ;)
