E36 sedaani ja E36 coupe käigukastid?
Me-rx
Peamine sõiduk: Audi C7 3.0tdi 180kw
Postitus Postitas Me-rx »
Tere!
Kas E36 sedaanide 325, 320,318 käigukastid sobivad E36 318 IS coupe'le alla, oskab keegi nõu anda?
Ei julge enam lammutuse mehi uskuda, kes kõige peale ütlevad, et sobib, osta ära.
M.
KLR
Peamine sõiduk: M54
Re: E36 sedaani ja E36 coupe käigukastid?
Postitus Postitas KLR »
Konkreetselt sedaani ja kupee kastide vahel küll erinevust pole, asi läheks liiga kirjuks ära. Iseasi on R6 kasti sobivus R4 otsa, seda peab küll täpsemalt uurima. Väidetavalt on E36 kastid siiski omavahel vahetatavad.
http://forums.bimmerforums.com/forum/sh ... 4224345a83" onclick="window.open(this.href);return false;
"The E36 has two kinds of transmissions for their engines, Getrag and ZF. The Getrag unit was used in 318s, 325s, and z3 1.9s. The ZF units have been matched up with the engines found in the M3, 328,and 6cyl z3s. The ZF transmission can be used in a chassis originally equipped with the Getrag unit but will require its shifter assembly and possibly a changeover for the driveshaft. Getrag units usually mate with a 4bolt driveshaft while ZF units came with either the 4bolt or the 6bolt unit driveshafts. Differentials used with the 318ti and z3 came with 4bolt flanges, so you will need to change one or the other to match if not originally equipped with the 4bolt end."
Fred
Peamine sõiduk: F34
Postitus Postitas Fred »
Ainult 4silindriliste kast läheb sulle alla.
Sobivad:
−E36
+316g M43
+316i M43
+316i M40
+316i 1.6 M43
+316i 1.9 M43
+318i M43
+318i M42
+318i M44
+318i M40
+318is M42
+318is M44
+318ti M42
+318ti M44
−E46
+316Ci M43
+316Ci N40
+316i N40
+316i N42
+316i 1.6 M43
+316i 1.9 M43
+316ti N40
+316ti N42
+318Ci N42
+318Ci M43
+318i N42
+318i M43
+318ti N42
Me-rx
Oh, suured tänud!
