E39 Vajaks abi veakoodi lugemisel.
Tcicko
Peamine sõiduk: E39 530D
Postitus Postitas Tcicko »
Äkki keegi oskaks lahti seletada , mida tähendab järgmine veakood:
1E 25 14 FF D8 40 09 8E 32 56 7C B8 40 1D 8D 1C 77 81 4D 40 09 77 32 62 81
PeeterA
Telefon: 51949859
Re: E39 Vajaks abi veakoodi lugemisel.
Postitus Postitas PeeterA »
Kus kohast ja millega selline lollus välja loeti? :lol:
Alari.
Peamine sõiduk: Bmw e38 730d
Telefon: 5181397
Postitus Postitas Alari. »
Tunduks nagu varjatud menüüst võetud koodid :D
s.toom
Peamine sõiduk: BMW E39 523i
Telefon: 5519929
Postitus Postitas s.toom »
freddy21 kirjutas:Tunduks nagu varjatud menüüst võetud koodid :D
+1
1 Fuel consuming signal from engine control unit faulty
2 Fuel consuming signal (ti-II) from engine control unit faulty
3 Road signal from ABS/ASC/DSC control unit faulty
4 RPM (tD) from engine control unit faulty
5 Coolant temperature sensor faulty
6 Temperature sensor
7 Outside temperature sensor
8 Fuel level sensor 1 (Fuel pump side)
9 Fuel level sensor 2 (without fuel pump)
10 Tension to high at the power supply
11 EGS signal disturbed
12 Power supply Pin 15
13 Power supply Pin R
14 Service Interval Display (SAI) Reset
15 Pressure Switch
16 Gong Sound (T1)
17 Gong Sound (T2)
18 Gong Sound (T3)
19 Current to high in the instrument cluster
20 Internal error in the LCM module
21 Internal error (IKE)
22 Vehicle speed signal (Tacho-A)
23 Instrument cluster -Bus (I-Bus)
24 Body-Bus (K-Bus)
25 Error during activation of the instrument in the instrument cluster
26 Undefined error
27 Internal Error
28 I-BUS error
29 Power Supply
30 Power Supply
31 Power Supply
32 Power Supply
33 K-BUS
34 Oil Pressure Control Light
35 Reverse gear recognition
3E Error by activation display
3F Instrument cluster current to high
44 Oil pressure switch
87 Body-Bus (K-Bus)
88 (I-Bus)
8B Gong Ton (T3)
8C Power supply Term. R
8D EGS Data lead disturbed
8F Power supply
90 Power supply Term. 15
91 Gong Ton (T2)
92 Gong Ton (T1)
BC Break fluid level
BD Electronic break power
BE LCM internal error
BF Instrument Cluster Internal Error
C1 ABS/ASC/DSC Signal(Tacho)
C3 RPM signal from DME control unit
C6 Output PIN 6 (Code EWS)
C7 Fuel tank sensor 1 (fuel pump side)
CD Fuel consumption signal DME 1
CE Outside temperature sensor
CF Service Interval Display (SIA) Reset
D3 Coolant temperature sensor
D5 Oil temperature sensor
D7 Fuel tank sensor 2 (without fuel pump)
DA Fuel consumption signal DME 2
F0 CAN-Bus off
F4 CAN Identification missing
F5 CAN Identification missing (ASC)
F6 CAN Identification missing (DME)
F7 CAN Identification missing (DME)
F8 CAN Identification missing (DME)
F9 CAN Identification missing (DME)
FA CAN Identification missing (EML)
FB CAN Identification missing (EGS)
FC CAN Identification missing
FD CAN Identification missing
ttsys
Postitus Postitas ttsys »
See list lebab jah kõikjal foorumites aga ilmselt seal on ka mootori koodist tulenevad variatsioonid.
http://www.bimmerforums.co.uk/forum/f15 ... es-t38563/" onclick="window.open(this.href);return false;
Tcicko
tegelt lõi ikka arvutis selle koodi, proovin pildi üles lasta mingiaeg
