If you hold the button on the signal stalk for a few seconds, it will go into programming mode where you can chose what to display buy pressing the corresponding buttons on the MID.
When you repeatedly press in on the turn signal stalk, the OBC display cycles through the various information types that it has in memory. The default sequence is: CONSUM1, CONSUM2, EXT. TEMP, SPEED, LIMIT, DIST and TIMER. If you want to change the display order, use the following procedure:
Press in and hold the turn stalk for about 5 seconds. The OBC display will change to Prog 1. Press the button corresponding to the first function you would like to have displayed in the sequence. For example, if you would like the outside temperature to be displayed first, press the TEMP button. The display will then change to Prog 2. Continue pressing the OBC buttons in the order you want, up through nine entries. You don't have to enter all nine - if you would like the display to cycle only between TEMP and RANGE, simply enter those two items as Prog 1 and Prog 2. When finished, press the SET/RES button to store the sequence in memory.
To revert to the default order, simply press SET/RES as soon as Prog 1 is displayed.
Kui seda mõtled
