Navi Navigatsioon TV on drive MK1 MK2 MK3 MK4 DVD
aise
Postitus Postitas aise »
:lol: kas siin foorumis on keegi kes oleks nõus jagama? kuna see kaart pole ametlik siis pole see ka piraatlus. tahaks võrrelda seda VDO kaardiga.
Mikk_O
Postitus Postitas Mikk_O »
no mina oleks nõus teatud tingimustel jagama seda! (mitte äriline eesmärk) nädala sees olen tallinnas. tel nr panen ps!
kiiirus
Postitus Postitas kiiirus »
Muhv kirjutas:TV
Sagedamini küsitud küsimused on kuidas sõidu aeg ka pilti näha.
530tD - siinse foorumi liige on oma varasemas postis kirjutanud:
Kes otsib see leiab...
Lahendus probleemile on järgmine:
Watch TV / Videotext during driving
This works on all 5/7 Series with the Mark I Navigation System (the one with the male voice).
On Mark II (the newer version with the female voice) you have to use "brightness" instead of contrast for TV and "color" instead of brightness for videotext to get the trick to work.
This works on the latest 99 7-series models as well. This does not appear to work for the latest BMWs sold in Europe (2000 onward, 3/5/7 series). The software updates for latest navigation CD-ROM's do not appear to affect or disable this trick.
set ignition to pos. II
enter TV mode
enter "settings"
enter "contrast"
when the green contrast bar is visible, push the knob and keep it pressed
turn ignition off (keep button pressed!)
wait 8-10 seconds (timing must be accurate!)
release the knob
turn on ignition again
Now the TV will operate while the car is in motion, though you certainly should leave that to your passengers only while driving.
To watch videotext use the same procedure as above, but choose "brightness" instead of "contrast" (thanks to Herbert Posner, who discovered this secret).
Uuemates versioonides on 2 varianti - osta Top Voxist või Top Audiost või Alptomist vastav plastjunniga kabla, mis aitab blokeeringust mööda pääseda, või tellida vastav teenus mõnelt vastavat aparatuuri omavalt seltsimehelt. Mulk2 vahendab soome kontakte, kus töö hinnaks 30EURi, Tartus Tehase 21 teeb kodanik viirus (5089942) sama asja ca 1000.- eest.
Kablade hinnakiri lae siit:
http://www.topparts.ee/files/MM-adapterid-05.pdf
Kle toimiski nagu kirjutatud,nüüd ei viska s6ites tv pilti eest,r66mup2evad kaass6itjale :)
Muhv kirjutas:Uuemates versioonides on 2 varianti - osta Top Voxist või Top Audiost või Alptomist vastav plastjunniga kabla, mis aitab blokeeringust mööda pääseda, või tellida vastav teenus mõnelt vastavat aparatuuri omavalt seltsimehelt. Mulk2 vahendab soome kontakte, kus töö hinnaks 30EURi, Tartus Tehase 21 teeb kodanik viirus (5089942) sama asja ca 1000.- eest.
See TV-On adapter on parim näide teadmatuse pealt raha teenimise võimalusest.
Uuel videomoodulil on vaja vaid 1 bitt ära muuta ja asi toimib!
Softi saab siit: http://www.bimmerboard.com/forums/posts/403911
TV aktiveerimiseks tuleb programm esmalt registreerida, see maksab 20€.
Muhv
Klubiliige EKBK
Postitus Postitas Muhv »
aise kirjutas::lol: kas siin foorumis on keegi kes oleks nõus jagama? kuna see kaart pole ametlik siis pole see ka piraatlus. tahaks võrrelda seda VDO kaardiga.
Linnapeal sahistatakse, et kutid teevad selle plaadiga 10-15k EEKi puhast päevas. Ei tea millal nad kinni pannakse...
Piraatlus on see igal juhul. Isegi kui nad seal ise midagi näppinud on ei kuulu algmaterjali autoriõigus kindlasti mitte neile. Selle kohta käivad päris karmid paragrafid.
Normaalselt see plaat ei tööta. (ootamatud resetid, hangumised, plaadi kinnijäämine masinasse...) Enda autosse panemisega ei kiirustaks...
rixa
Postitus Postitas rixa »
Muhv kirjutas: Linnapeal sahistatakse, et kutid teevad selle plaadiga 10-15k EEKi puhast päevas. Ei tea millal nad kinni pannakse...
Aga siis käib siin metsik ulgumine, et miks Navteq ei suvatse meie kaarti korda teha. Krt, enamik teenib juba ammu nii palju, et jõuaks seda ka ametlikult osta, aga kus sa sellega. Ja need, kes ei teeni, neil pole seda ka tegelikult vaja.
EnnR
Postitus Postitas EnnR »
rixa kirjutas: Aga siis käib siin metsik ulgumine, et miks Navteq ei suvatse meie kaarti korda teha. Krt, enamik teenib juba ammu nii palju, et jõuaks seda ka ametlikult osta, aga kus sa sellega.
Õige märkus! Kust saab osta ametlikku kaarti!? Niikaua kui seda Eestis ametlikulkt saada pole, ei taha kuulda mitteühtegi viginat piraatluse teemal!!! Ja kui müügile tuleb, siis palun eestikeelse manualiga! See tootjate piraatluseteemaline vigin hakkab närvidele käima, samas aga kui juttu teha seadusega nõutud riigikeelsest manualist, siis miskipärast valitseb vaikus...
X1 E84 2.0d 2011 a.
Ilves
Postitus Postitas Ilves »
EnnR kirjutas:Õige märkus! Kust saab osta ametlikku kaarti!? Niikaua kui seda Eestis ametlikulkt saada pole, ei taha kuulda mitteühtegi viginat piraatluse teemal!!!
Noh, see pole otseselt vabandus piraaditsemiseks, sest navikaardi olemasolu ei ole just põhiseaduslik kodanikuõigus ;) Aga üldiselt tuleks UM-i peedistada, sest kuskil 1.5 aastat tagasi saadetud järelepärimises lubasid nad kaarti 2007 aasta lõpuks.
TiitR
Peamine sõiduk: E70 xDrive30d
Postitus Postitas TiitR »
Ilves kirjutas:
Minule öeldi Tartu UM-st kuu aega tagasi ka, et selle aasta lõpuks (e60-le siis).
Muhv
Klubiliige EKBK
EnnR kirjutas: Õige märkus! Kust saab osta ametlikku kaarti!? Niikaua kui seda Eestis ametlikulkt saada pole, ei taha kuulda mitteühtegi viginat piraatluse teemal!!! Ja kui müügile tuleb, siis palun eestikeelse manualiga! See tootjate piraatluseteemaline vigin hakkab närvidele käima, samas aga kui juttu teha seadusega nõutud riigikeelsest manualist, siis miskipärast valitseb vaikus...
Mina ostsin Helvar Merkast (oli vist) VDO plaadi. Väga hästi töötab.
EnnR
Ilves kirjutas: Noh, see pole otseselt vabandus piraaditsemiseks, sest navikaardi olemasolu ei ole just põhiseaduslik kodanikuõigus ;)
Vabandan, et pisut OT, aga kommentaariks eelnevale. Navikaardi omamine pole tõesti põhiseaduslik õigus, kuid vastavalt EV seadustele tuleb siinmüüdav toode varustada riigikeelse manualiga. Seaduse täitmine ja sellest kinnipidamine ning võrdse kohtlemise printsiip on ikka küll juba Põhiseaduse pärusmaa. Ei ole nii, et piraaditeemal tõstetakse kisa taevani, aga muus osas on mokk maas...
PS. Mis ei tähenda, et pooldaksin kohe seda piramist.
Muhvile
Selle teema alguses tood ära küllalt põhjaliku ülevaate erinevatest navidest ja versioonidest, aga paraku ei selgunud kiirel vaatlusel, et milline navi versioon (MK-3, -4?) Sul siis seda Helvar Merkast ostetud VDO plaati loeb?
X1 E84 2.0d 2011 a.
Muhv
Klubiliige EKBK
EnnR-ile - MK4
juudas
abi paluks
Postitus Postitas juudas »
tere
sai just soetatud 2002 aasta 4,4 i x5 :) hea auto powerit rohkem kui vaja.
Aga..
probleem 1
Tahaks telekat ka sõiduajal vaadata! kas keegi oskab öelda mis teha ja kes teeks? ei tea mina mis MK mul on (teada oleks hea ju)
asja l puudub navi ja ega see ei huvita kah eriti.. eesti peas ja ülejäänud riigid jooksevad telefuunis tom-tomi toel.
see eest olemas orig (vist?) cd box :)
Probleem 2
tagaistujate juures AV pistik.
Kas sinna dvd ühendades hakkab see ka ees telekas av menüüst mängima?
juba ette tänades :)
jeeh 4,4 x5 2002
EnnR
Muhvile
Muhv kirjutas: Mina ostsin Helvar Merkast (oli vist) VDO plaadi. Väga hästi töötab.
Kas too Merka asub Tallinnas Laagris Maksimarketi vastas?
X1 E84 2.0d 2011 a.
Mulk
Peamine sõiduk: A6 4G QUATTRO
Postitus Postitas Mulk »
juudasele
kas sul on siis ainult tv funktsioon ja navi lugejat pagasiruumis polegi voi.Kui ei ,siis pole sul seal mingit MK lugejat.Kui tehasest navi siis peaks olema MK3 veel arvan, 02. lõpuautos ehk juba MK4.märts 01.a hakati MK3 panema , millal X ile MK4 pandi täpselt ei tea.Tv saad sõiduajal nägema siis kui käiä natuke auto ajukallal.Priit just paar posti tagasi kirjutas mida vaja muuta et saaks näha.
juudas
aidähh mulk 2 le.
ei tea jah kas originaalis see navi oli aga enam igadahes pole ja menüüs kah siukkest kohta pole nigu navi.
äkki peaks kahh seda nupulevajutust 8 seki jooksul proovima?
jeeh 4,4 x5 2002
TiitR
juudas kirjutas:aidähh mulk 2 le.
Tõmba tagant luuk lahti ja vaata vasakule poole tiiva sisse, sealt peaks vastu vaatama tavaliselt 2 välimuselt pea ühesugust seadet - cd box ja navi seade.
juudas
vaatasin... ainult cd box on. Aga ikkagi kuda sõiduajal pilti näeb?
jeeh 4,4 x5 2002
juudas kirjutas:Aga ikkagi kuda sõiduajal pilti näeb?
Pöördu kodeerija poole, kui ise ei suuda softi ja interfeisi muretseda.
juudas
äkki keegi oskab öelda möne kogenenud kodeerija andmeid?
jeeh 4,4 x5 2002
aise
juudas kirjutas:äkki keegi oskab öelda möne kogenenud kodeerija andmeid?
ma ostsin täna jupid ära, teen IBus -> PC skeemi ja proovin enda auto peal kohe ära ka, kui töötab siis võin aidata. annan siin teemas märku kuidas läheb.
juudas
anna teada kindlasti..
jeeh 4,4 x5 2002
aise
juudas kirjutas:anna teada kindlasti..
:D töötab :cool: kodeerisin oma navi kah nats, vene keele panin peale ja vin koodi panin õigeks (navi seade on teisest autost pärit). tv kodeerimist ilma rahata ei saa, peab programmi tegijale veits rulli viskama siis saab seda ka teha.
aise kirjutas:tv kodeerimist ilma rahata ei saa, peab programmi tegijale veits rulli viskama siis saab seda ka teha.
No selles valguses tundub ju küsitud 20 eurot ikka päris muidu. Kui võrrelda kasvõi nende karbikestega, mida müüakse?
aise
priitv8 kirjutas:
arvata on jah, mingi 50+ euri küsitakse selle juhtmjupi eest, mis tv vahele käib (läbi tagumiku ninaoperatsioon :lol: ). ma maksin vennale 20EUR ära ka ja programm regatud, õhtul kui aega proovin ka TV siis vabaks teha :)
M2ki
Postitus Postitas M2ki »
Jootsin ka seekmi kokku aga midagi vist läks valesti, sest infot lugeda saab mis ibus's jookseb aga ise päringuid nagu teha ei saa, timeout. Peab selle Tx poole skeemil üle vaatama.
aise
M2ki kirjutas:Jootsin ka seekmi kokku aga midagi vist läks valesti, sest infot lugeda saab mis ibus's jookseb aga ise päringuid nagu teha ei saa, timeout. Peab selle Tx poole skeemil üle vaatama.
diood valepidi?
läheb vist ot´ks? äkki peaks NavCoderi jaoks eraldi teema tegema?
aise
TV kodeeritud ja toimib :) kui keegi tahab ka siis PS kaudu edasine.
M2ki
Sain korda, TV töötab :) , seriali pikenduse juhe oli vigane, ja kuna kummagil läpakal com porti polnud, siis tuli laua arvuti autosse vedada :D
PiltPilt
aise
M2ki kirjutas:Sain korda, TV töötab :) , seriali pikenduse juhe oli vigane, ja kuna kummagil läpakal com porti polnud, siis tuli laua arvuti autosse vedada :D
PiltPilt
irw @ interface, ma mõtlesin, et minu oma on jube :lol: peaasi, et töötab
mul õnneks on tööläpakal com port olemas, oma läpparil enam pole.
