E36 coupe el. akna probleem
RuZzz01
Postitus Postitas RuZzz01 »
Nimelt, kunde poolne ukseklaas ei jookse soravalt üles ega alla vaid liigub ainult ca 3 cm ühe vajutamisega, suht tüütu on nuppu nagu närvihaige toksida. Algselt pakuti, et viga võib comfort relee's olla, kuid mul puudub selline asi!? Tegemist on 93 a masinaga, oskab keegi veel miskit välja pakkuda kus kala võib olla?
siiim_k
Re: E36 coupe el. akna probleem
Postitus Postitas siiim_k »
Miski relee tal niikuinii olemas on ilmselt siis viga selles relees.
RuZzz01
Noup...kõik juhtmed mis uksest tulevad jooksevad otse ühte suurde musta blokki. Kuhu lisaks veel 100 muud juhet.
siiim_k
Kas klõps mitte ukse sees ei käi? Relee või selle sarnane asi on kondlasti kuskil.
RuZzz01
Poleks seda teemat püstitand, kui näeks mingit releed seal.
siiim_k
"Both my windows are messed up, it's common on the e36.
Mine only go up/down in 2 inch increments, so you have to keep pushing the button to get
them to move.
The reason for this problem is that the window motor has a sensor composed of a donut
magnet on the motor shaft. This magnet spins around in a set of coils which tell the car
where the window is. Unfortunately the glue that holds this magnet to the shaft breaks down, and the magnet starts to slide around, meaning that the car can't tell when the
window is up or down anymore. I've seen people try to fix this by opening up the window
motor and gluing the donut magnet back in its place. I tried this, with no success, and by
the time it was over I was glad just to get the window motor assembly back together. I
wouldn't recommend trying to fix it like that, although new motor assemblies cost around
$200 I've learned to live with it for the time being, I may get it fixed one day, ''
pm siis uus mootor(kasutatud)
või proovi remontida.
RuZzz01
Asoo, et selline asi hoopiski. Pulli pärast võiks korra seda mootorit enne ise natuke uurida, äkki saab asja. Ei pea enam mingit olematut releed taga ajama. Tänud sulle!
siiim_k
Pm võid vaadata jah, ega sellest midagi hullu ei saa juhtuda. Nagu ma aru saan siis tuleks see magnet omale kohale tagasi liimida. Loogiliselt peaks see olema midagi elastsemat liimi ja samas võiks sooja ka taluda kuna ukse sees suvel tõuseb see temp päris soojaks ilmselt. Ehk mingi hermeetiku taoline või kahe komponendiga liim vms.
Edu ettevõtmisel ja anna siis teada kas said toimima.
